Use this procedure to display UNI ports associated with particular IP multicast routes.
  1. In the navigation pane, expand Configuration > Fabric > SPBM.
  2. Select the IpMcastRoutes tab.
  3. Select the desired row, and then select the UNI Ports tab to display the UNI ports associated with a particular stream.
IpMcastRoutes Uni Ports Field Descriptions
Use the data in the following table to use the IpMcastRoutes Uni Ports tab.
Name
Description
Group
Specifies the group IP address for the IP Multicast over Fabric Connect route.
Source
Specifies the IP address where the IP Multicast over Fabric Connect route originated.
VsnIsid
Specifies the VSN I-SID. Layer 2 VSN and Layer 3 VSN each require a VSN I-SID.
DataIsid
Specifies the data I-SID for the IP multicast route. After a BEB receives the IP multicast data from a sender, a BEB allocates a data I-SID in the range of 16,000,000 to 16,512,000 for the stream. The stream is identified by the source IP address, group IP address, and the local VLAN the stream is received on. The data I-SID is a child of the scope or VSN I-SID.
SourceBeb
Specifies the source BEB for the IP multicast route.
VlanId
Specifies the ID for the C-VLAN.
VrfName
Specifies the VRF name.
NniPorts
Specifies the network-to-network interface (NNI) ports for the IP multicast route.
SPBM runs in the core on the ports that connect to the core. These ports are NNI ports. Ports facing a customer VLAN are user-to-network interface (UNI) ports.
Type
Specifies the type for the IP multicast route.
Bvlan
Specifies the B-VLANs for the IP multicast route.
